Activity Forums Adobe After Effects shatter effect – extruded sides look bad
  • shatter effect – extruded sides look bad
    Posted by Amber Navarrete on June 21, 2011 at 9:29 pm
    I’m using the shatter effect for the build of a brick wall. My image is brick therefore I’m using the brick pattern shape. When I add the effect and extrude to give the pieces the look of an actual brick it creates lines on the sides – I prefer the extruded sides to be one solid color. Is it possible to change this? I’ve attached an image for reference.
    https://i1.creativecow.net/u/201280/brick.png
    Amber Navarrete replied 15 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Roland R. kahlenberg
    June 21, 2011 at 9:39 pm
    Look at Shatter’s Texture section. I suggest that you add CC Force Motion Blur or ReVisionFX’s SmartMotionBlur to enhance the effect.
    HTH
    RoRK
    Intensive AE Training in South East Asia.
  • Amber Navarrete
    June 21, 2011 at 9:50 pm
    Jesus – I stared at all the settings over and over and somehow didn’t see that. I feel like a moron. Thanks for your help!!!!
  • Amber Navarrete
    June 21, 2011 at 10:04 pm
    New problem – I was using custom shapes with the effect. When I change the color of the sides it forces the bricks to show up. Any way to avoid that or is it just how the effect works?
    https://i1.creativecow.net/u/201280/brick2.png
    June 21, 2011 at 11:11 pm
    Hi Amber, please post a PNG of your Custom Map.
  • Amber Navarrete
    June 21, 2011 at 11:23 pm
    I have a brick wall made up of many shapes like the one posted below. I want each individual shape to build (with the brick shatter effect) which is working but the extruded edges look like crap because of the lines. Ideally I’d like them to be a solid color without the rectangles of the effect. Is this possible?
    Here is the example: https://i1.creativecow.net/u/201280/example.png
    June 22, 2011 at 12:43 am
    Read the comment from AE legend, Brian Maffit on how to create custom shatter maps here – https://library.creativecow.net/toula_jesse/Custom-Shatter-Maps/comments
    HTH
    RoRK
  • Amber Navarrete
    June 22, 2011 at 3:07 pm
    Thanks Roland. The effect can be confusing but now it’s making total sense. I really appreciate your help on this. Keep on rocking.
    Thx,
    Amber
