Activity Forums Adobe After Effects Shatter effect blurring texture layer
  • Shatter effect blurring texture layer
    Posted by Christian Hopkins on July 21, 2011 at 8:36 pm
    I’m trying to use the Shatter effect to explode a ground plane. Unfortunately the texture is being quite badly blurred when the camera (and I’ve tried all 3 camera options), is in position (low angle looking across the ground as you might expect – nothing unusual). The preComp which is feeding the texture is clean, large squares so the blurring is very noticeable. I could use Particular but I like the depth that Shatter offers. The Pre Comp with the texture is large (3000 x 4000px), due to the foreshortening needed.
    The image is reasonably sharp when the camera is rotated -75 on the x axis. I need it to be around -99, and the blurring makes it useable.
    Any ideas would be much appreciated.
    Thanks.
    Christian Hopkins replied 15 years, 1 month ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    July 22, 2011 at 3:56 pm
    Not really clear- maybe posting a few stills would help.
    Have you considered Trapcode Form for the job?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Christian Hopkins
    July 25, 2011 at 10:58 pm
    Sorry for not posting an image sooner.
    The image shows a solid with and without Shatter applied. It seems to be the acute angle in conjunction with Shatter results in a horrible, unwanted blur.
    Thanks for your suggestions on Particular, I had tried it actually, and Form but I was looking for volume that Shatter can add to the fragments, without depth it’s not a convincing floor. Unless Particular and Form can have 3d particles (like a cube). I couldn’t figure out how or if that’s possible.
    It should be a 3D job I suspect, but I don’t have the knowhow, and this job doesn’t have the budget.
