Activity › Forums › Adobe After Effects › shatter doesnt work
  • shatter doesnt work
    Posted by Gregory on July 6, 2005 at 10:00 pm
    hi folks
    as i understood, the time i apply a shatter effect and make a prewiew, it supose to blow up the bricks by default. well, in my case it didnt. i checked the blue sphere radius and also the distance..still it didnt.
    does anybody can guess what the problem is?
    pls
    thanks a lot in advance
    z
    Kathlyn Lindeboom replied 21 years, 2 months ago 4 Members · 4 Replies
  • Steve Roberts
    July 7, 2005 at 2:42 am
    I just created a solid, then applied shatter and made a RAM preview. It blew up the solid, with all falling bricks gone after 3 seconds. I made no changes to any shatter settings.
    You must have changed something. Did you try spinnning the camera around to see if the sphere is actually touching the object to be shattered?
    Steve
  • Mike Clasby
    July 7, 2005 at 5:31 am
    Try hitting the “reset” for Shatter, at the top of the Effect Palette.
    The Effect Shatter effect is coovered in detail in this pdf, After Effects 5.5 Effects Documentation (ZIP: 3.2M) at:
    https://www.adobe.com/products/aftereffects/indepth.html
    Shatter is in pdf 4, pgs 17-26.
    Lots of reading but lots of control.
  • Gregory
    July 7, 2005 at 12:23 pm
    thanks alot for previos answer
    as i understand now, shatter works only with still images…right
    does it work also with videos or may there is an other effect for this porpose
    thanks again
    have a nice weekend
  • Kathlyn Lindeboom
    July 7, 2005 at 6:08 pm
    We also have a beginner’s shatter tutorial in our library:
    https://www.creativecow.net/articles/unguren_ben/shatter/index.html
    A really nice tutorial from Ben Unguren. It’s for 5.5, but I’m sure it would still be applicable.
    Kathlyn Lindeboom
    The Mistress of Mmmooooo!
