Activity › Forums › Adobe After Effects › Sharpen a footage 25% and how to deinterlace
Posted by Andrea Di berardino on May 4, 2013 at 6:00 pmHi everyone, as the title, can someone please explain me what does mean sharpen a footage 25% and how to deinterlace in AE?
Thank in advance.
Andrea Di Berardino
Andrea Di berardino replied 13 years, 4 months ago 2 Members · 4 Replies -
Tudor “ted” jelescu
May 4, 2013 at 11:04 pmdeinterlace:
https://library.creativecow.net/articles/kramer_andrew/deinterlace.php
sharpen – sounds like you need to read this first:
https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103a9d3c597-7bada.html
then just search for the many tutorials on this matter
Tudor “Ted” Jelescu
Senior VFX Artist -
Andrea Di berardino
May 5, 2013 at 5:32 pmThanks Ted,
you’ve been very helpful.Andrea Di Berardino
Andrea Di berardino
May 6, 2013 at 7:30 pmHi Dave, thanks for replay.
I have this project and unfortunately i cannot update any footages.
In the job description, they ask me:Please sharpen all footages 25% before applying your effects on top.
Select DEINTERLACED due to the possible generation degrade.I do not really understand.
Andrea Di Berardino
Andrea Di berardino
May 7, 2013 at 7:56 amDear Dave, i also was thinking like you about 25%, the value in AE does not work in percent and 1000 as you said, is too much. So here is a report of the footages. Thank for your help.
Format profile : QuickTime
Format : DV
Codec ID : dvcp
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Width : 703 pixels
Original width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Bits/(Pixel*Frame) : 2.414Andrea Di Berardino
