Activity › Forums › Apple Final Cut Pro Legacy › sharp logo
sharp logo
Posted by Jeffrey Durkin on October 28, 2008 at 11:26 pmHey guys, I’ve imported a logo into the end credits of a short film,
and it dos’nt look very sharp…… on a monitor or on my flat screen.It’s a 300 dpi psd file. What should I use?
My FCP timeline
SD 720×480
24p
using FCP6Thanks
JeffDavid Bogie replied 17 years, 10 months ago 4 Members · 5 Replies -
Ernie Santella
October 28, 2008 at 11:22 pmSome thing to check. Did you render it in the timeline? Are you resizing it? And you don’t need 300dpi, 72dpi will do.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com -
David Bogie
October 28, 2008 at 11:38 pmAny DPI will do, DPI is meaningless in video. There are only pixels in video.
There are way too many possible answers to the question. so let’s start with another. What size is the logo, in pixels, before you place it on the timeline?
And, what’s the image format of this logo?bogiesan
Zane Barker
October 29, 2008 at 4:04 amBefore all of those other things, WHAT CODEC IS YOUR TIMELINE?
If you are editing in a DV codec then that is most likely the problem. The moment you render ANY graphic in a codec program its going to look bad.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Jeffrey Durkin
October 29, 2008 at 5:05 amThanks for the info zane,
the timeline is 720×480 using the DV/DVCPRO compressor.
The logo is a PSD, the background video is HDV 1080 24 with that codec.
I’m working with mixed video, (HDV/SD) and logo’s
are layered in on top of it all.Does this help?
I have FCS2, do I need to use another program?Thanks
Jeff -
David Bogie
October 29, 2008 at 2:47 pm> Thanks for the info zane,
are layered in on top of it all. Does this help?
I have FCS2, do I need to use another program? <Oh, we assumed you were working in the larger format.
Your logo, and all of your high def video, must be rasterized and then downconverted (way down) to the terrible DV codec which totally blows and why we seem to think it’s an acceptable standard is beyond me.None of your stuff can possibly look any better than DV can deliver and that ain’t much. There is a good article on kenstone.net (search the archives, it’s old) by Philip Hodgetts that explains how to get the best text performance out of DV. Most of the advice applies directly to working with any vector art.
bogiesan
