Activity › Forums › DaVinci Resolve › Sharing LUTs between systems on a Resolve Database server
  • Sharing LUTs between systems on a Resolve Database server
    Posted by Kevin Cannon on August 21, 2013 at 12:45 am
    Is there a function of Resolve or Resolve database server that allows the sharing or syncing of LUTs on multiple machines?
    For example, if we use a custom LUT for Alexa on one work station, currently we copy it to each workstation and refresh the lists. Sometimes we fail to get everything identical on all systems, and need to render something off on a different station. It would be convenient if that information could travel with the database server. Any such thing?
    KC
    Prehistoric Digital
    Kevin Cannon replied 13 years, 1 month ago 3 Members · 4 Replies
  • Juan Salvo
    August 21, 2013 at 1:21 am
    you could do a little rsync script between stations.
    color/post/workflow
    https://JuanSalvo.com
  • Dan Moran
    August 21, 2013 at 2:40 pm
    not sure if it works on mac but on linux we use a alias folder that can link folders so resolve thinks its looking at the cinespace folder but its actuallly a folder on our san that all machines can see
    Dan Moran
    Colourist
    Smoke & Mirrors: London
    http://www.danmorancolor.com/blog
  • Juan Salvo
    August 21, 2013 at 3:13 pm
    yeah symlinks would work on the mac as well.
    color/post/workflow
  • Kevin Cannon
    August 23, 2013 at 6:33 pm
    Thanks guys!
    Resolve couldn’t follow an alias created using the OS, but creating a symlink with the ln -s terminal command worked properly.
    For reference, I used this command:
    Theater1:~ Username$ ln -s (drag the Shared SAN path here) /Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT
    Prehistoric Digital
