Activity Forums Apple Final Cut Pro Sharing Libraries without needing to relink
  • Sharing Libraries without needing to relink
    Posted by Loren Risker on December 5, 2014 at 9:31 pm
    I have a library with 7 events and over a thousand clips, some of which are AVCHD, which is slow to relink.
    I have an exact copy of the media on 2 different drives, one for me and one for my producer.
    All of the media, cache, proxies, etc are outside of the library so that we have a very small library.
    The problem is, when we send the library back and forth it takes a long time to reconnect all the media, like over an hour.
    I’ve considering naming the hard drives the same name (haven’t tested yet but will once the relink finishes) but I was wondering if anyone has found a better solution?
    We’re mostly using this to make notes on the project file, so it’s very tedious to have to relink everything just to get back up and running.
    Am I missing something?
    OutOfFocus.TV – Original series, music videos, mini-docs.
    Loren Risker replied 11 years, 9 months ago 2 Members · 3 Replies
  • Eugeny Korkhin
    December 5, 2014 at 10:39 pm
    Hi
    Identical names of drives and matching folder structure should help.
  • Loren Risker
    December 6, 2014 at 12:25 am
    The names are identical, the drives are cloned.
    Renaming the volume so they have the same name worked. I guess that will have to work, but I can see this leading to frustration when I had the drive back.
  • Loren Risker
    December 6, 2014 at 12:27 am
    Except it won’t reconnect the proxy media. Aaargh, so close.
