Activity Forums Adobe After Effects Sharing compositions accross multiple projects
  • Sharing compositions accross multiple projects
    Posted by Violet Rose on January 13, 2007 at 12:59 am
    I have multiple different AE projects that use the same compositions. After spending hours updating a comp in one project I don’t want to have to repeat all of that work. Does anyone know if it is possible to take a composition from one project in After Effects 7.0 and import it into another AE project?
    Scott Hathaway replied 19 years, 8 months ago 3 Members · 2 Replies
  • Mike Clasby
    January 13, 2007 at 2:03 am
    If you File>Import>File then click on the aep that contains the comp, you want to use, AE will open that project in a new folder, then you can delete other comp if you want.
    You can also drag the aep into your new comp.
  • Scott Hathaway
    January 16, 2007 at 12:52 am
    Oh my gosh! I’ve been struggling with this for weeks not knowing what to do! Thank you Yikes!
