Activity Forums Apple Final Cut Pro Share/Export Using Compressor Settings – Custom Compressor Settings are not there
  • Share/Export Using Compressor Settings – Custom Compressor Settings are not there
    Posted by Randy Burleson on August 22, 2012 at 10:01 pm
    When I use Share/Export Using Compressor Settings the custom settings that I made in compressor are not showing up.
    What is going on? is there a bug with Compressor or FCP X?
    Is there a way to fix this?
    Morten Hansen replied 14 years ago 4 Members · 5 Replies
  • Bret Williams
    August 23, 2012 at 5:22 am
    The new compressor? You have to buy the new version on app store for this function.
  • Randy Burleson
    August 23, 2012 at 1:20 pm
    I have version 4.0.4 that IS the new version.
  • Bret Williams
    August 23, 2012 at 3:46 pm
    Just checkin
  • T. Payton
    August 23, 2012 at 6:19 pm
    I would do the normal stuff, trash FCP prefs, repair permissions.
    Make sure you can see the compressor settings in ~/library/application support/compressor
    If that doesn’t work, trash and redownload Compressor.
    If that doesn’t work, trash and redownload Final Cut Pro.
    It is a good idea to keep a “fresh” copy of Final Cut and Compressor that hasn’t been launched around.
    T. Payton
    OneCreative, Albuquerque
  • Morten Hansen
    August 29, 2012 at 6:36 pm
    I had the same problem. But trashing and reinstalling wasn’t enough. I had to completely remove the app and all settings. You can use AppZapper for this. It completely *zap* all settings and related files. Doing this did the trick for me.
