Activity › Forums › Apple Final Cut Pro › Share/export fails during time machine back-up
  • Share/export fails during time machine back-up
    Posted by Oliver Peters on September 5, 2019 at 2:16 pm
    Anyone run into this? I tried to export a 30 min ProResHQ master file and it failed at about 25%. Tried multiple destination drives. Failed each time without trace of any partial/incomplete file on any of these destination drives. I noticed Time Machine was backing up. So I quit the active back-up and then the export was fine.
    – Oliver
    Oliver Peters – oliverpeters.com
    Joe Marler replied 7 years ago 2 Members · 1 Reply
  • Joe Marler
    September 5, 2019 at 3:53 pm
    I haven’t seen a repeatable case on a single ProRes output file, and I always have TM running.
    However when I’ve used the new 10.4.4 feature to batch export many (as in 500+) ProRes clips from the Event Browser, sometimes a few don’t get exported. I haven’t had time to pursue that.
    Is there any commonality, such as they are on the same hub, same Thunderbolt string, or any on a NAS?
