Activity › Forums › Apple Final Cut Pro Legacy › shared media raid – cheaper options – opinions wanted!
  • shared media raid – cheaper options – opinions wanted!
    Posted by Mark Palmos on March 4, 2008 at 11:55 am
    Hi there all,
    I would love your opinion.
    My main workplace have asked me for advice on upgrading their systems, and part of what we want is two MacPro’s sharing fibre channel storage. I have never done fibre storage myself, so I asked a local vendor to come up with a quote.
    I almost fell over backwards i saw the bottom line, it was an apple xsan 8gig setup and the quote was for close to $60k. I then asked him to provide a bare bones non xsan fiber network solution and it now costs only (pffft, yeah right) about $23,000.
    i have roughly doubled the prices for converting to $$:
    QLogic 4Gb Fibre Channel Switch with 8 active ports & Single PSU (1U) $3200
    8TB RAID Video/Audio Storage – <7TB @ RAID 5 (3U) $12,000
    SNS Storage Area Network (SAN) Software $1200x2
    NMR Level 1 SAN/NAS Technical Support (12 Months) $3800
    NMR SAN Testing, Delivery & Installation $1500
    Does all this stuff seem necessary to you? Is there another way other than fibre? Would fibre need so much support, software, expensive switch etc???
    Tx
    Mark.
    Mark Palmos replied 18 years, 6 months ago 9 Members · 26 Replies
  • 26 Replies
  • Peter Wiggins
    March 4, 2008 at 12:17 pm
    For true shared storage it looks about right. If you start squeezing the budget, then things will suffer.
    There are a number of ‘san in a can’ options you could look at though.
    If you are in the UK, give Root6 a call.
    Peter
  • Walter Biscardi
    March 4, 2008 at 1:31 pm
    Shared fibre storage is expensive which is one reason why we have not gone to that. We have 16TB of RAID 5 Storage running 500MB/s but it’s 8TB dedicated to each of 2 suites. If we need to move anything across from one to the other, we simply use our Ethernet network to move files.
    The best solutions for Fibre Channel Shared storage for my money are from Ciprico and Facilis. Facilis makes the easiest SAN on the market where everything is hosted on the array. You simply have a single Fibre Channel cable coming off your Mac. Ciprico has been making Fibre Arrays for a long time and they have solid solutions for the Mac.
    But as for your pricing, it all seems right in line. Cheaper alternatives are simply not out there for shared fibre storage or really for shared storage in the first place. it’s an expensive proposition.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Mark Palmos
    March 4, 2008 at 1:38 pm
    Hi Peter,
    Thanks, I called them and they will call back… it seems they have Facillis an DVS Products, so we will see if the prices are any cheaper.
    In my ignorance, I would have guessed there was a way of putting a fibre controller card into each MacPro, then put a bunch of 1TB SATA drives into a basic PC with a SATA Raid controller and fibre network card and then connect that to both MacPro’s via fibre cable…
    but it seems not. ;-(
    Mark.
  • Walter Biscardi
    March 4, 2008 at 1:46 pm
    [mark palmos] “it seems they have Facillis an DVS Products, so we will see if the prices are any cheaper.”
    Facilis is generally the most expensive, but they are the easiest to run and from what folks have told me who are using them, they are rock solid.
    Read my Blog!
  • Mark Palmos
    March 4, 2008 at 1:47 pm
    Thanks Walter,
    Its pretty new, and shocking to me.
    We will see what these Root6 people charge for the Facillis or DVS SANs.
    Do you use the secondary Ethernet socket on the MacPro to gigabit-connect the two systems up directly? We would have to do something like that and avoid going through the whole network since our IT Dept imposes way too much security.
    BTW earlier today i was rendering something and browsed off to the Cow and clicked on one of your tutorials (easy setups), and you had me giggling… so thanks!
    Till later
    Mark.
  • Mark Palmos
    March 4, 2008 at 1:48 pm
    hmm,
    it seems we may have to do the separate raid5 / gigabit ethernet route for sharing.
    tx
    mark.
  • Walter Biscardi
    March 4, 2008 at 2:01 pm
    [mark palmos] “Do you use the secondary Ethernet socket on the MacPro to gigabit-connect the two systems up directly?”
    We just connect them up directly. We’re only using the one socket on the Mac Pro.
    Read my Blog!
  • David Peralta
    March 4, 2008 at 2:44 pm
    Hey There,
    since you said you only want 2 stations connecting, you might want to take a look at this smaller product from editshare:
    https://www.editshare.com/index.php?option=com_content&task=view&id=190&Itemid=189
    its for smaller production houses based on their full editshare solution.
    -Dave
    hmm… I wonder what this button does…
  • David Smith
    March 4, 2008 at 3:17 pm
    Mark,
    You might be interested in this thread, starting with the fifth post:
    https://forums.creativecow.net/thread/98/869210#869210
    Regards,
    David
  • Mark Palmos
    March 4, 2008 at 3:29 pm
    hello you two.
    thanks very much for the new (for me) ideas… i will check into both of your ideas/links and will report back… tx,
    Mark.
Page 1 of 3
