Activity › Forums › Apple Final Cut Pro Legacy › Share… Current Settings
  • Shane Ross
    October 12, 2010 at 12:39 am
    No. Render…export via FILE>EXPORT>QUICKTIME MOVIE…self contained, using sequence settings.
    What other application will be able to export a sequence FROM WITHIN FCP? Only FCP has that sequence, so you need to export FROM FCP…
    Shane
  • Dustin Parsons
    October 12, 2010 at 1:10 am
    Thanks for the speedy reply! Sorry, I guess it was pretty stupid to have specified “within FCP”.
    Basically, the reason I ask is because I know that with FCP 7 you have the option of exporting using File > Share… which sends your timeline to Compressor (letting you continue to work in FCP), however, as far as I know there is no option for using Share… without going through the trouble of creating a Compressor setting to have the same specs as your FCP Sequence.
    Please correct me if I’m wrong. Thanks again.
    Mac Pro | Leopard 10.5.7
    2.66GHz Dual-Core Intel Xeon | 4GB Ram
    Final Cut Pro Studio 2 | Avid Media Composer
  • Shane Ross
    October 12, 2010 at 1:25 am
    Well, I dont’ use Share. I like having a file that I export and then can do what I want with it. Always have it to do whatever…so I don’t have to go BACK to that project and export again. Exporting a self contained file takes very little time, especially when fully rendered.
    Shane
