Activity Forums Adobe After Effects shape/stroke animation with continuesly blend effect?
  • shape/stroke animation with continuesly blend effect?
    Posted by Mátyás Bosnyák on May 7, 2017 at 10:13 am
    Hy guys!
    I have an idea, what i’m trying to do in the days, but i can’t figure out.
    I want to create an animation with one shape (but the stroke is the point), wich behave like a loop.
    I want to blend this animation with a greater circle, so the steps between the blend marks have to move.
    The visual is like a topographic map, but the looped transition should be smooth, the space between the contours like equal.
    All suggestions are welcome! ❤
    Best whishes,
    motyodlee
    Greg Gesch replied 9 years, 4 months ago 2 Members · 1 Reply
  • Greg Gesch
    May 7, 2017 at 11:40 pm
    Hi Matayas, you could use the Liquify effect on concentric circles (which could be created by using the Radio Waves effect and saving as an image).
