Activity Forums Adobe After Effects Shape set to cast shadow only, but I can see it
  • Shape set to cast shadow only, but I can see it
    Posted by Alejandro Pérez blanco on August 17, 2012 at 8:30 am
    I am testing the new raytracing capabilities on a project. A few objects are composited over some footage. They look great, but they take really a long time to render, so I prefer to pre-render 3d elements with an alpha channel and then make a composite. Everything works fine, except a layer I put there set to cast shadows only.
    When I turn off every 2d layer in the background, the layer set to only cast shadows becomes visible. It doesn’t happen when I switch over to Classic 3d.
    Am I missing something?
    Thanks in advance.
    Alejandro Pérez blanco replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
