Activity › Forums › Apple Final Cut Pro › Shape Mask changing size after export
  • Shape Mask changing size after export
    Posted by Ben Chastney on August 3, 2015 at 2:41 pm
    Saw one other post on this with no resolution. Here are the details.
    We do sports videos. We use an inverted circular “Shape Mask” on a black color generator to make a circular highlight appear around an athlete we’d like to designate. FCPX added that great updated “Shape Mask” filter that we can easily re-size to fit around the athlete on each clip.
    The issue we’ve started to encounter is although the “Spot-shadows” as we call them are properly sized in FCPX after we send to compressor the size of the spot-shadow changes on the compressed version. See these images:
    Project settings:
    Any ideas? Please help, thank you!
    Ben
    Winston Edgoose replied 10 years, 1 month ago 8 Members · 10 Replies
  • 10 Replies
  • Mark Suszko
    August 3, 2015 at 4:02 pm
    At a guess, the filter/effect you generated was built with a different frame size than the footage it is being applied to. But that’s just a guess. Does this come up if you pre-render the timeline before sharing to Compressor? What I’m getting at is that I don’t think the problem is actually *in* compressor, but rather, in some step FCPX is doing in the pre-render.
  • Jeremy Garchow
    August 3, 2015 at 4:16 pm
    If you compound that clip before sending to compressor, does that help?
  • Ben Chastney
    August 3, 2015 at 6:04 pm
    [Mark Suszko] “I’m getting at is that I don’t think the problem is actually *in* compressor, but rather, in some step FCPX is doing in the pre-render.”
    See the first image below everything rendered, looks correct, but then….
    [Jeremy Garchow] “If you compound that clip before sending to compressor, does that help?”
    … upon compounding the clip the error is duplicated in the FCPX timeline. See the images below.
    Any clues here?
  • Jeremy Garchow
    August 3, 2015 at 6:33 pm
    Sure, first compound the clip, then add the mask to the compound.
  • Ben Chastney
    August 3, 2015 at 6:34 pm
    Sounds delightfully easy! We’ll implement
  • Tony Hoffman
    September 29, 2015 at 2:18 pm
    I am having the same problem. I tried putting the mask into a compound clip but the problem remains. Has anyone found a solution to this?
  • Bryan Jackson
    October 14, 2015 at 8:18 pm
    I’m having the exact same issue. Video looks great in the final project edit, but when I export the Mask is moving. It’s incredibly annoying – Would love to understand what we’re doing wrong.
  • Anthony Donovan
    June 13, 2016 at 3:01 am
    I’ve had the exact same issue, and I’ve yet to find a solution for it. Ben, have you figured this one out?
  • James Cude
    June 15, 2016 at 10:17 pm
    Try converting the mask to points, as described in this post by Charlie Austin: https://fcpxpert.net/2015/04/13/fcp-x-10-2-first-look/
  • Winston Edgoose
    August 24, 2016 at 9:54 am
    The convert to points worked for me!
    Thanks for the tip you saved me from some frustration!
