Activity Forums Adobe After Effects Shape Layer oddness
  • Shape Layer oddness
    Posted by Ken Latman on August 17, 2009 at 7:58 pm
    I encountered an oddness that I was wondering if anyone else has.
    I have a shape layer that is a star.
    First I did this: I set the layer itself (not the shape) to rotate counter clockwise 4 times.
    I then made this layer 3D and changed it’s x orientation to about 65°.
    I then decided I wanted the star to become smaller towards the end. I set one keyframe same at the begining to 100 then at the end to 0. As the you progress down all of a sudden it looks like the perspective changes abruptly.
    I tried isolating the shape layer with all its attributes to a composition but that didn’t change the behavior.
    I tried have the shape itself change size and rotation while allowing the layer to maintain that 65° position. still the same.
    When I put the shape layer and its rotation and scale properties into a composition and then make that composition a 3D layer with a 65° angle, no problem.
    Am I missing some rule of AE now with shapes? i knew the order of render is M(masks) E(effects) T(transformations). How do shape layers fall into this model?
    Todd Kopriva replied 17 years, 1 month ago 2 Members · 1 Reply
  • Todd Kopriva
    August 17, 2009 at 8:32 pm
    “Within each raster (non-vector) layer, elements are applied in the following order: masks, effects, transformations, and layer styles. For continuously rasterized vector layers, transformations occur before masks and effects.”
    (from the “Render order…” section of After Effects Help)
    Shape layers are vector layers, so the order is 1) transformations, 2) masks, 3) effects.
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
