Activity › Forums › AJA Video Systems › Shake and Broadcast (kona2)
  • Shake and Broadcast (kona2)
    Posted by Mark Everson on July 8, 2005 at 6:33 pm
    Any one out there get shake and Kona2 to play nice?
    If so, any tips, or Kona setup templates that the comunity could use?
    We are setting up a shake system on a G5 and we need to out put video to a client broadcast monitor.
    If not Kona, then what? We have not yet purchased, but we have 1 kona2 in the facility already, so it would be nice to stay in the Aja club.
    Any info would be great, but soon please as we need to move forward.
    Thanx.
    Mark!
    Peter Mcauley replied 21 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    July 11, 2005 at 6:36 pm
    I don’t think there’s a problem with the Kona 2 and Shake playing nice at all… should be an external video output setting in Shake to allow you to select the K2 as the device… should be plug and play I’d think…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Peter Mcauley
    July 11, 2005 at 6:55 pm
    My Kona 2 and Shake work well together. Go into the globals tab, open up “guiSettings” then”broadcastHighQuality”. Under”broadcastMonitorNumber” set tthe number to monitor you want display the video. In my set up I have two 23″ Cinema displays so I set it #3. #2 would display the video on my second cinema display. Then in the main viewer in Shake enable the broadcast monitor ” The button that looks like little tv. You should now be getting display on your video display. Just be careful of the gamma settings in shake, Know what you are looking at.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.1 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
