Activity Forums Adobe After Effects shadows n’ stuff
  • shadows n’ stuff
    Posted by Martin Earle on April 26, 2009 at 7:41 pm
    Dear All,
    Is it possible to export the shadows out of a composition with an after fx light without the objects casting the shadows themselves?
    Thank you!
    Martin
    Martin Earle replied 17 years, 5 months ago 2 Members · 2 Replies
  • Adriano Moraes
    April 26, 2009 at 7:57 pm
    Hi there. I guess you want to export the shadows without the objects. If so you can select the objects hit AA or go down to the Material Options and under Casts Shadows set it to only.
    Hope it helps.
    Cheers.
    ninguem.
  • Martin Earle
    April 26, 2009 at 10:37 pm
    Thanks ever so much! I knew there would be a simple way…
