Activity Forums Adobe After Effects Shadows in a Composite
  • Shadows in a Composite
    Posted by James Murphy on March 21, 2008 at 7:26 am
    I am compositing a shot where a guy runs across a traffic-stricken street by using two static shots: A) the guy runs across an empty street and B) actual traffic. I’ve got all the masking done, and the guy is in the action pretty well.
    My problem is he stops in front of a large bus that casts a shadow on the ground. The guy does not receive this shadow cast by the bus. How can I make it look as though the bus is truly passing in front of the guy and the bus’s shadow is also changing his light?
    Randy Mcwilson replied 18 years, 5 months ago 2 Members · 1 Reply
  • Randy Mcwilson
    March 22, 2008 at 1:53 am
    1. Create a black solid on the layer above the man
    2. Duplicate the layer with the man and move it above the black solid layer
    3. Turn on track matting for the black solid layer and select alpha matte (this will use the alpha info from the second layer of the man which is above it)
    4. Adjust the opacity of the black solid layer to make it seem more like a shadow.
    5. Add another mask to the black solid layer if you need the shadow to move across the man. Use keyframes to change the shape of the mask over time.
    hope this helps.
    Randy
    Eternity…don’t miss it for the world.
