Activity Forums Maxon Cinema 4D Shadows from glass?
  • Shadows from glass?
    Posted by Helena Masterson on May 16, 2013 at 9:19 pm
    Hi, I’m new to C4d and I’m trying to produce a shadow from a glass cube with an object in the middle. I have an infinite white background and one light (accepting shadows). I dont seem to be able to get a soft shadow on the ground for both the cube or the object inside (due to the transparency I suspect). Can anyone help?
    Helena Masterson replied 13 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 16, 2013 at 11:17 pm
    transparency is not an issue, it should work. What are your light’s settings in the shadow tab (or can you post the scene file)?
  • Helena Masterson
    May 16, 2013 at 11:22 pm
    Hi Brian,
    Thanks for the response. I just read your message and went back through my light settings. I found the shadow option and turned it on and it worked! Don’t know how I missed it. Thanks again!
