Shadow rendering issue
Hello,
I seem to be having an issue with rendering shadows in CS6. I’ve never seen this before and I can’t see any settings that would cause it. It only seems to be relating to a single light, which was actually copied from elsewhere where the issue wasn’t visible. I’ve also copied the same light into a different point elsewhere in the same composition and it has no problems.
Here’s the same with the shadow intensity increased (normally at 20%, increased to 109% for the sake of making it more visible)
I’m pretty baffled!
Thanks in advance for any help.
Steve
