Activity Forums Maxon Cinema 4D shading – maybe dumb question
  • shading – maybe dumb question
    Posted by Jonas Espinoza on July 17, 2006 at 9:54 pm
    is body paint the only way to selectively shade parts of a polygon, or is there another work flow. I am trying to figure out how i could for example have say a cube, and be able to apply different shaders to each side. thsnks
    Brian Jones replied 19 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    July 17, 2006 at 10:45 pm
    The manual has the best description (Texture Mapping/Texture Tag/Selection – pg 869 of the v9 manual) but basically you just choose the poly’s you want to have a particular texture, do a Selection/Set Selection (which makes a selection tag). Add the texture to the object, then drag the selection tag you just made into the Selection box of the Texture tag.
