Activity Forums Maxon Cinema 4D Shader Effector
  • Shader Effector
    Posted by Syed Iqbal on April 23, 2017 at 4:38 pm
    I raised this same query but I guess it was not responded to because I made it somehow complicated. I hope it will be answered this time.
    I have few basic geometry sitting in a cloner. These cloned objects are placed on a plane object which is used as an object of cloner. I have an obj sequence that I want to use as source for my shader effctor and if obj sequence is not the right choice then i may go and make a PNG based output with alpha to use as source map for my shader effector.
    I want to do 2 things:
    1) My cloner should pick colors from my shader effector
    2) Z position of my cloner objects should be affected by the shader effector.
    Please let me know if you want me to clarify it more but I need your help to sort this out.
    Thanks.
    Syed
    Adam Trachtenberg replied 9 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 23, 2017 at 9:42 pm
    As far as I know the Shader Effector will only accept image formats (obj is an object format).
    Probably best to post your basic scene file set up as far as you’ve gotten.
