Activity Forums Adobe After Effects Several Words lika a rope of pearls
  • Several Words lika a rope of pearls
    Posted by Christian Kruse on June 2, 2011 at 11:10 pm
    Hey there,
    I just found an interesting effect on a youtube clip where some lines of words appear like they were on a role of pearls. Cannot describe it very good – but I just would like to know, if there is some easy and fast to edit possability in After Effects to create such an animation.
    Video: https://www.youtube.com/watch?v=nUZvP2n1R9c&feature=related
    (Second 0:19 – 0:21)
    Thanks for any suggestions.
    Tian
    Graham Macfarlane replied 15 years, 3 months ago 4 Members · 6 Replies
  • Roland R. kahlenberg
    June 3, 2011 at 12:53 am
    Here are a couple of URLs for you to dig in deeper into the Expression used to create the effect.
    https://forums.creativecow.net/thread/227/13758
    https://lesterbanks.com/2011/01/swinging-kinetic-text-expressions-for-after-effects/
    HTH
    RoRK
    Intensive AE Training in South East Asia.
  • Christian Kruse
    June 3, 2011 at 9:02 am
    Thanks for this post.
    I tried to use the expression I found on that website – but it does not work. 🙁 It always says there are Syntax Errors and the expression will be deactivated now.
    Any suggestions?
  • Anders Hattne
    June 3, 2011 at 10:26 am
    For the bounce use the Inertial bounce expression as Roland R. Kahlenberg said.
    For the pearls CC Sphere. Precompose the animation and apply the sphere effect. Use the bounce expression in the z rotation of the effect.
    In this animation the Spheres are 3d layers.
    http://www.ardillamedia.com
    June 3, 2011 at 1:38 pm
    Hi Christian, you were provided with two URLs, which one did you try. You should also provide more information on the property that you are applying the Expression onto and the type and number of keyframes you have applied on that property.
    ANy other information you can provide in terms of the layer type (2D/3D) may be helpful.
    Cheers
    RoRK
  • Christian Kruse
    June 3, 2011 at 2:05 pm
    I first tried this URL: https://lesterbanks.com/2011/01/swinging-kinetic-text-expressions-for-after-effects/
    I did everything like written and putted the second expression code to the rotation property. But it says Syntax Error Line 5. (if I delete line 5 it says Syntax Error Line 11 etc.)
    The Layer is a 3D Layer and I did not put any other effects on it.
    Afterwards I tried the other URL with the post of Filip Vandueren and yeah – it works so far that I can create a 4-line text where every line is swinging parallel. But I want it more like an accordion … like in the video I posted. First there should only be one line visible and from that on the other lines should unfold line by line. Like a piece of paper that has been folded several times and now unfolds.
    Tian
  • Graham Macfarlane
    June 3, 2011 at 6:04 pm
    Hi Christian,
    For both the position and rotation codes:
    The web site has formatted the – (minus) characters so that AE doesn’t understand them. Just replace them with a normal – (minus) within AE
    Also on line 5, I think that code should read as
    n = n-1;
    I tried them with these adjustments and it works great!
    Very neat bit of code by Lester Banks! Thanks Roland for the link!
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
