Activity Forums Adobe Premiere Pro Setup for color monitor?
  • Setup for color monitor?
    Posted by Kevin Carlson on July 14, 2022 at 10:06 pm
    I had to change computers so my AJA TTap thunderbolt 2 to SDI box won’t work with my thunderbolt 3 computer. Thank you Apple.
    Now I have a BMD Ultastudio Monitor 3G that feeds my Flanders monitor.
    The monitor is getting a 2K signal since I edit in 4k and that’s the highest it can receive. But the problem is it is slightly letter boxing the picture and thus compressing it vertically.
    Is there a way to force PP or BM Desktop Video Setup to send a 1080P signal?
    Kevin Carlson replied 4 years, 1 month ago 3 Members · 6 Replies
  • Tero Ahlfors
    July 15, 2022 at 8:52 am
    There is a setting where you can scale the output signal either up or down in the playback settings in Premiere.
  • Kevin Carlson
    July 15, 2022 at 2:50 pm
    Thanks for the response, Tero,
    I assume you mean Preferences/Playback/Setup on the BM device?
    Yes, I am scaling down, but I think it is scaling down to the 2K signal and the wrong aspect ratio, which is compressing the image and letterboxing it.
    Is that what you’re talking about?
  • Tero Ahlfors
    July 16, 2022 at 8:59 pm
    If that doesn’t work you’ll need to work in a timeline that has a supported resolution/framerate that the I/O device can output and what the monitor supports. Resolve is nicer in this regard because you can have a separate monitoring resolution from the timeline.
  • Kevin Carlson
    July 19, 2022 at 1:19 am
    I think you are right, Tero. At least that’s what it’s looking like.
    I wish I could still use my AJA box, as it allowed you to decide what output it sent. Thanks for forcing me to “upgrade” Apple 🙁
    That’s really good to know about Resolve! I had not heard that. I may have to finally give it a try…
  • Mark Grance
    July 19, 2022 at 9:14 pm
    Not an answer for you but…
    1.) A thunderbolt 2 to 3 adaptor won’t work with the TTap?
    2.) Are you editing 4K or actually UHD?
  • Kevin Carlson
    July 20, 2022 at 1:09 am
    3840×2160
    Actually, AJA has been pretty helpful, and looks like there actually might be a chance that I could use an adapter. But my understanding is that Apple tries very hard to make nothing T2 work on a T3 computer, and with OS updates blocks drivers and such. I’ve tried using it, and the TTap shows up in system report, but it won’t be seen as a capture device. Thanks for the response, Mark Grance.
