Activity Forums Adobe Premiere Pro Setup Alredy Running, can’t install Adobe Premiere Pro CS3
  • Setup Alredy Running, can’t install Adobe Premiere Pro CS3
    Posted by Robert William on July 5, 2010 at 1:17 am
    OK i’m not running anything else, i did run Adobe Premiere Pro CS3 before but setup.exe wouldn’t respond and i also ran CS5 few days before that. but thats it.
    Well this is what it is.
    Brian Louis replied 16 years, 2 months ago 2 Members · 3 Replies
  • Robert William
    July 5, 2010 at 1:28 am
    I think i know the problem, I ran a setup but never appeared. It showed that file extracting thing but after that actual setup appeared. then well i ran again and the message came up. I don’t know what to do now.
  • Robert William
    July 5, 2010 at 1:39 am
    I also have another question, does Adobe CS3 support wmv files?
  • Brian Louis
    July 5, 2010 at 11:44 am
    [robert william] “does Adobe CS3 support wmv files?”
    Yes, be aware that wmv is a highly compressed file that is a end product and they may not edit too well.
    If the setup isn’t on the bar at the bottom of the screen, open the taskmanager and terminate any instances of it there, reboot and try again, sometimes if you accidently click the mouse on the screen you can disappear an app.
