Activity › Forums › DaVinci Resolve › settings to grade a Movie in Davinci
  • settings to grade a Movie in Davinci
    Posted by Laura Fernandez on January 29, 2018 at 9:32 am
    I have some questions regarding to grading a movie in devinci
    I use a Monitor Zunzheng AM420 that offers the possibility to switch the colorspaces. I normally use rec709 but for the movie my intention is to switch it to DCI-P3 colorspace.
    In the Color Management in Davinci i was also gonna switch the Timeline color space from Rec.709 Gamma 2.4 to DCI-P3
    To export i was gonna use the easy DCP option
    Questions:
    1) Is it enough to switch the monitor from 709 to DCI-P3? Or am I suppose to calibrate it again once its already in DCI-P3?
    2) Switching the Timeline color space to DCI-P3 is correct? Or should I change it to DCI- XYZ?
    3) Exporting easy DCP in the delivery page is correct?
    Thanks!!!!!!
    Laura Fernandez replied 8 years, 8 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    January 29, 2018 at 9:55 am
    [Laura Fernandez] ” but for the movie my intention is to switch it to DCI-P3 colorspace.”
    Why?
  • Laura Fernandez
    January 29, 2018 at 10:13 am
    becasue as far as I know (and i might be completly wrong) the DCI-P3 is the color space I “should” use to grade a movie that is gona be released…. but i might be wrong… thats why I ask ☺
  • Tero Ahlfors
    January 29, 2018 at 11:08 am
    [Laura Fernandez] ” the DCI-P3 is the color space I “should” use to grade a movie that is gona be released…. “
    Nope. The end result needs to be in DCI XYZ when you make a DCP. There are a lot of features that are graded in Rec709 and then converted when it’s done. The thing about DCI-P3 grading is that it should be done with a projector in a proper DI theater. You can’t emulate projector reflectance on a monitor.
    Unless you really know what you’re doing you’d probably be better off by grading in Rec709.
  • Joseph Owens
    January 29, 2018 at 4:02 pm
    If you want to work from a colorspace that lends itself to various export standards, then that is what the ACES color management approach offers.
    You will not be working, strictly speaking, in any specific release format — what you will be doing is monitoring in the colorspace currently selected. Picking 709 under that system is perfectly acceptable if you are monitoring the output on a 709-calibrated display. The same would be true if you picked P3 and you were working in a projected P3 environment. That’s how it is supposed to work.
    To learn more, search for “Display-referred” color management practices.
    jPo, CSI
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Laura Fernandez
    January 30, 2018 at 2:58 am
    So that means i better work in 709 and then the easy DCP will do the proper conversion to DCI-P3 XYZ ?
    Thanks for the answer!
  • Laura Fernandez
    January 30, 2018 at 2:59 am
    Noted. Thanks!
