Activity › Forums › Apple Final Cut Pro Legacy › settings for video to fit CD-ROM
Posted by Gabriele Gismondi on September 15, 2010 at 5:25 pmhi,
i’ve been asked for a video to put in a CD ROM (4 audio tracks+1 video). is there a best way to mantain quality-size ratio? i suppose to use a QT movie codec anyway..
thanksJerry Hofmann replied 15 years, 11 months ago 3 Members · 7 Replies -
Rafael Amador
September 15, 2010 at 5:31 pmHi Gabriele,
H264 is the codec to use. High quality and small size.
Choose the data rate according with the size, and set “Key-frames: Automatic”.
rafael -
Jerry Hofmann
September 15, 2010 at 5:33 pmThe best export of a sequence is a QT movie export using “current settings” and being sure that “make self contained” is turned on. Of course you need to have sequence and it’s settings result in a file small enough to fit on a CD.
We’d need a lot more information about how long and what format the video you’re editing is.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Gabriele Gismondi
September 15, 2010 at 5:38 pmhi jerry, thanks for the answer.
i’m editing a 4 minutes music video, 1280x720p, sequence is ProRes, audio 48k 16 bit, QT movie exported (current settings) is 480M sized. guess is if it’s already a good size or I should try h264 as Rafael suggested..
thanks again -
Rafael Amador
September 15, 2010 at 5:46 pmTry some 4.000Kbps.
You must try to keep the data rate low because you are playing from a CD.
Once you have the clip toast it in a data CD to see how plays in RT.
rafael -
Jerry Hofmann
September 15, 2010 at 5:54 pmIf the file is to be playable on any machine with QuickTime installed for just viewing (not editing) Follow Rafael’s advice. If it’s to be edited then it’s best to not use h.264
Jerry
