Activity Forums Adobe Premiere Pro settings for exporting a master ProRes file
  • settings for exporting a master ProRes file
    Posted by Clermond Ferrand on August 4, 2012 at 7:12 am
    I have a 5min 23,97fps sequence with mostly .mts files from a Pana GH2 and some QT ProRes files.
    If I choose for export same settings as sequence Premiere chooses “MPEG Preview” as Format.
    If I to choose ProRes as codec and 23,97 fps manually the frame rate of my exported QT changes in a strange way. Here’ s a sample of 23.43fps but I had also 23.621
    These are my settings (sorry it’s German localisation) Does anybody see a mistake in that?
    How would you set up the export for QT ProRes (requested by the customer)
    Thanks for your time
    Clermond Ferrand replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
