Activity Forums Apple Final Cut Pro Legacy Settings for capturing 24p video and outputting to DVCAM
  • Settings for capturing 24p video and outputting to DVCAM
    Posted by Patrick Briar on October 2, 2006 at 1:42 pm
    What would be the correct audio/video settings and sequence settings for capturing video shot at 24p with 3:2 pulldown for DV output? Can you capture DV footage (to be integrated into the same project) with these settings or do you have to capture seperately with DV settings?
    Patrick
    Patrick Briar replied 19 years, 12 months ago 2 Members · 2 Replies
  • Shane Ross
    October 2, 2006 at 4:40 pm
    IF you are outputting to DV, why remove the pulldown? Just capture 29.97…use the DV/NTSC Easy Setup. DVCAM tapes cannot play footage at 23.98, only 29.97.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Patrick Briar
    October 2, 2006 at 4:45 pm
    Ok. Thank you. Can you tell me when it is appropriate to use the 24p capture settings? Is that only if you are outputting to 24p?
