Activity › Forums › Apple Final Cut Pro Legacy › settings
settings
Posted by Andrew Zador on May 16, 2009 at 6:16 amCould someone please explain me how to change sequence settings and clip settings? How do I make them match?
John Fishbackreplied 17 years, 3 months ago 6 Members · 6 Replies
Rafael Amador
May 16, 2009 at 7:05 am -
Tom Wolsky
May 16, 2009 at 1:25 pmYou can’t change the clip settings without converting the file with something like Compressor. You can change the sequence settings using the Audio/Video Settings function.
It would be much simpler if you just gave exact information about your media and what you’re trying to do rather than us trying to guess and extract the information from you one question at a time.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Andrew Zador
May 16, 2009 at 3:09 pmI am using Final Cut Pro S 1.4. The camcorder I have is a Canon XH A1 high definition. I only have problems capturing with this camcorder. When I use my old one (Sony, analog) the capture is fine and I never have to render any files.
Arnie Schlissel
May 16, 2009 at 6:51 pmLook up sequence settings & clip settings in your FCP manual. It’s all explained there, so there’s no real need for someone to explain it here.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Steve Eisen
May 16, 2009 at 9:08 pmEasy Setup! Couldn’t be easier.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
John Fishback
May 17, 2009 at 6:19 pmIf you upgrade to FCP6, it will set settings for you. After opening a project, when you drag your first clip to a sequence, if the seq settings are different from your clip, FCP will ask if you want it to change the seq settings to match your clip.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
