Activity › Forums › Avid Media Composer › Setting up for a project shot on film
  • Setting up for a project shot on film
    Posted by Scott Davis on May 29, 2014 at 5:44 pm
    I’ve worked on projects that where shot on film; but posted and delivered in video. I have a short film now that might want to end up back on film. What should I be aware of while setting this project up? Is there a good resource that explains the workflow for film to Avid to film?
    Thanks for any insight or thoughts.
    Scott Davis
    View Scott Davis's profile on LinkedIn
    Michael Phillips replied 12 years, 3 months ago 2 Members · 3 Replies
  • Michael Phillips
    May 30, 2014 at 1:33 am
    The Avid user guide has a lot of information on managing film based projects with the intent of going back to film.
    For starters, you’re first going to create a project that matches the video format/resolution and frame rate – for example, 1080p/23.976. Then select the film format in order to generate lists.
    Michael
  • Scott Davis
    May 30, 2014 at 4:54 pm
    Thanks Michael,
    Quick question: If footage has already been imported in (at the correct format/resolution) but into a project where the film option was not selected; can I create a new project with the film option selected and bring the bins into this film project?
    Scott Davis
  • Michael Phillips
    May 30, 2014 at 5:07 pm
    Yes, you should be able to.
    Michael
