Activity › Forums › Adobe Premiere Pro › Setting up Audio in Premiere
  • Setting up Audio in Premiere
    Posted by Scott O’hara on October 29, 2016 at 12:09 am
    Hey All,
    Been editing for quite a while, but still having trouble pinning down the best setup for audio mapping/panning and exporting.
    Particular example below.
    Getting Mono Source files. 3 people mic’d total of 6 mono channels.
    Channel 1: Mix L
    Channel 2: Mix R
    Channel 3: Boom
    Channel 4: Lav 1
    Channel 5: Lav 2
    Channel 6: Lav 3
    I’m creating a multi-channel sequence with Standard tracks with the eventual output to stereo with option of discrete channel exports if need be (from multichannel).
    My questions are:
    -Right now, the boom and lavs are center panned. When done with the edit I create a stereo submix and direct the tracks through that to get stereo. Or I cut and paste the multichannel sequence into a stereo sequence.
    -BUT! I thought I remember a sound mixer telling me they should be panned left (the mono tracks at first). Then when going to a stereo export you fill the right channel to get true stereo. But I totally forgot what he told me as it was years ago. But I thought center panning mono tracks will give you a muddied sound.
    -What’s the CORRECT way to set this up in Premiere for multichannel sequences, then getting stereo out of that with true L and R panning for the cleanest sound?
    Any help would be greatly appreciated.
    Scott O’hara replied 9 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
