Activity Forums Apple Final Cut Pro Legacy Setting up an edit network
  • Setting up an edit network
    Posted by Joseph Wilkins on July 8, 2011 at 1:20 am
    So I run a small post house… working with FCP.
    I have three workstations and up until now have kept projects organized on hot-swappable firewire drives.
    But now I need a solution that is shared over the network… preferably a wireless network, but possibly not.
    Keeping in mind price is an issue, what lower cost solutions are you guys using?
    I have thought of running a mac tower I have as a shared computer with all the drives on, then having all other computers networked to it… is that going to be fast enough over an airport extreme network?
    Mark Raudonis replied 15 years, 2 months ago 2 Members · 1 Reply
  • Mark Raudonis
    July 8, 2011 at 4:35 am
    Joseph,
    I will point you to two forums here on the cow where your question is best answered:
    First, check out “SAN- Storage Area Networks”, and then try “Arrays & Raid SetUP”.
    Be warned that Bob Zelin prowls those forums and you just might get a taste of his “shotgun”.
    Quick answer to your question: No, you can’t do that! It’s gonna cost you some money to achieve
    a workable solution. The good news is that the cost is going down.
    Good luck.
    Mark
