Activity Forums Adobe After Effects Expressions Setting Transforms For Other Layers
  • Setting Transforms For Other Layers
    Posted by Royce Jacobs on December 19, 2010 at 1:59 am
    I am working on a comp that is going to be automated (with scripts) to open a text file and make new text layers for each line in the file. I then have text layers whose text sources are defined by the new layers’ index numbers (1 through 3).
    I’ve gotten that far, but now I need to hide the first 3 layers, either by changing the opacity to zero or to somehow make them invisible to rendering. This will all run on a website with aerender though, so I need this to be done in the script, as there will be no user interface to AE.
    So how can I set the opacity to zero of layers 1-3 based on index through a script?
    Royce Jacobs replied 15 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 19, 2010 at 6:47 pm
    You’re talking about a script, not an expression, correct?
    With a script you could do something like this (assuming myComp is a variable referencing the comp):
    for (i = 1; i <= 3; i++){
    myComp.layer(i).property(“Opacity”).setValue(0);
    Or this:
    myComp.layer(i).guideLayer = true;
    Or this:
    myComp.layer(i).enabled = false;
    If you are talking about an opacity expression, it would just be:
    index <= 3 ? 0 : value
    Dan
  • Royce Jacobs
    December 20, 2010 at 2:30 am
    Perfect, thanks so much! I am running it in a script; I think I’ll use the setValue(0).
