Activity › Forums › Apple Final Cut Pro Legacy › Setting the timecode on FCP
  • Setting the timecode on FCP
    Posted by Aliya Al-hassan on June 7, 2010 at 5:14 pm
    Hello,
    sorry if this is a really simple question, but I am just starting out!
    I cannot work out how you can set the timecode on the timeline in FCP.
    As I am going to be outputting to tape, I need to have exact timecode on the timeline and I can’t work out how to do this at all. I will need to set the bars at about 09583000 and the actual edits starting at 1000000.
    Please help.
    many thanks
    A
    John Fishback
    replied 16 years, 3 months ago
    2 Members · 5 Replies
  • John Fishback
    June 7, 2010 at 5:29 pm
    Go to Sequence Settings > Timeline Options tab > Starting Timecode. And I think you mean 00:58:30:00 for your bars start point. That will lead up to 1:00:00:00
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Aliya Al-hassan
    June 7, 2010 at 5:38 pm
    Hi thanks for that.it is also the issue of where the edits are placed on the timeline. For example. I want my first edit to start at 1000000 and my second edit at 10.02.00.00. How do I move the edits themselves to these points? Thanks so much
  • John Fishback
    June 7, 2010 at 6:31 pm
    Select the clips – normally I hit the letter “T” four times – it will turn into a double arrow facing right – then when you click with it, it will select all the clips to the right. Then, drag them to the time you want.
    John
  • Aliya Al-hassan
    June 8, 2010 at 5:37 pm
    Thanks that’s really useful.
    Is there a more exact way of getting things to places on the timeline rather than just dragging them?
  • John Fishback
    June 8, 2010 at 6:10 pm
    Type a timecode into the field in the upper left of your timeline and hit Enter. The playhead will snap to that point and you can place an IN.
    John
