Activity Forums Maxon Cinema 4D setting render to negative time
  • setting render to negative time
    Posted by Bruce Gaber on April 7, 2020 at 8:04 pm
    I’ve built a fairly complex piece and needed to add some material at the very beginning. I moved to frame T= -100. Everything was fine until I went to render when the render settings frame range “from” would not let me enter -100. It just defaults to frame 0. Is there any simple fix here? Or must I try to select and drag all my KFs in the F-curves window forward by 100 frames…a pretty risky business if I miss any of them
    Thanks…and be well
    Bruce
    Bruce Gaber
    Mac Catalina 10.15.4
    iMac 27\” late 2019
    3.6 GHz Intel Core i9
    40 GB 2667 MHz DDR4
    Radeon Pro Vega 48 8GB
    DR 16.1
    AE 17.0.0
    C4D R21.207
    vimeo.com/BodhiBruce
    visionrising.com
    Dance Without Reason
    Jim Scott replied 6 years, 4 months ago 2 Members · 1 Reply
  • Jim Scott
    April 9, 2020 at 1:53 am
    I don’t know how to solve the render settings issue, but if you do a “Select All” (CMD+A) in the dope sheet window you can then drag all the keyframes by grabbing any keyframe or the orange highlight bar at the top.
