Setting position of particles?
Hi guys,
I’ve been tasked with creating some visualisations of galaxy surveys for my cosmology group, and at the moment I have simply written some python code to output plots, which I animate manually, and have manually had to code additive blending. It is not ideal. Video in question is here: https://www.youtube.com/watch?v=Zmy-ycEHY8k
I would like to move to AfterEffects using some particle system (inbuilt/particular/other), because it would make life a thousand times easier. However, I cannot find a way to manually set particle positions. I have the x,y,z coordinate of each particle, and can save them out to csv or any format, however I cannot find a way of importing those positions into AE and using them in a particle system!
Does anyone know of a way to do this?
Cheers
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
