Activity › Forums › Adobe After Effects › Setting path vertices using scripting
  • Setting path vertices using scripting
    Posted by Andrew Yardy on August 22, 2022 at 2:33 am
    I’d like to spawn shape objects with small variations in the shape vertex positions.
    I seem to be able to get a handle to a shape’s vertices but not sure how to set the values for individual vertices.
    Can anyone offer suggestions??
    shapeLayerContents=nodeLayer.property(2);
    shape.property(2).property(1)
    pathVerticies=shape.property(2).value.vertices
    verticiesCount=pathVerticies.length
    for(var i = 0 ; i < verticiesCount;i++){
    v=pathVerticies[I]
    pathVerticies[0]=[10,10]
    Andy
    Andrew Yardy replied 4 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 22, 2022 at 2:40 pm
    This example shows how you could add [10,10] to each vertex of a shape path:
     var myComp = app.project.activeItem;
    var myLayer = myComp.layer(1);
    var myPathObject = myLayer.property("Contents").property("Shape 1").property("Contents").property("Path 1").property("Path");
    var myPath = myPathObject.value;
    var myVertices = myPath.vertices;
    var v;
    for (var i = 0; i < myVertices.length; i++){
    v = myVertices[i];
    myVertices[i] = [v[0] + 10, v[1] + 10];
    myPath.vertices = myVertices;
    myPathObject.setValue(myPath);
  • Andrew Yardy
    August 22, 2022 at 11:13 pm
    Thanks, Dan so much.
    Using the property names is very helpful to see the object hierarchy.
    Cheers
    Andy
