Activity › Forums › Adobe After Effects › Setting Output module to PRORES HQ as a default
  • Setting Output module to PRORES HQ as a default
    Posted by James Mulryan on February 15, 2011 at 9:29 pm
    Can anyone please tell me how to set the output module to PRORES HQ as a default setting.
    I have to change it every time I add a composition to the render queue.
    thanks
    James Mulryan
    Sunset Park Media, LLC
    Santa Monica, CA
    info@jamesmulryan.com
    Kevin Camp replied 15 years, 7 months ago 2 Members · 1 Reply
  • Kevin Camp
    February 15, 2011 at 9:38 pm
    click the arrow/triangle next to the output module and choose ‘make template’ to openthe output module templates.
    at the top of that window you can set the movie default.
    the act of opening the output module settings also creates a new template called ‘untitled 1’ that you may not want to keep. just click ‘delete’ to remove it from the section bellow the ‘defaults’ settings.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
