Activity Forums Adobe After Effects Expressions Setting Opacity based off of z position
  • Setting Opacity based off of z position
    Posted by Bryan on January 7, 2007 at 10:40 pm
    Once again, I’m here to bug.
    I need a script that will set a layer’s opacity based off of a range of z position. So, say, 2000 z or higher is zero opacity, and 500 z or lower is 100 percent opacity (bearing in mind that the z might then go past zero into -z).
    Thanks.
    -Bryan
    Dan Ebberts replied 19 years, 8 months ago 2 Members · 1 Reply
  • Dan Ebberts
    January 8, 2007 at 1:13 am
    linear(position[2],500,2000,100,0)
    Dan
