setting length of Gen Media preset
Posted by Richard Klimesh on July 28, 2006 at 10:12 pmI can’t seem to be able to change the lenght of a generated media preset from the default 5 seconds. I want to make a text event that is 3 seconds long that I can insert from a preset. I set the length to 3 seconds, name the preset and save it, but every time I call it up it has reverted to 5 seconds. Please advise.
klimvid
Gary Alan replied 20 years, 2 months ago 4 Members · 13 Replies -
Don Bloom
July 28, 2006 at 10:28 pmWhen you change the time of the generated media you must save it as the new preset.
So if you change it to 3 secs. name it 3 sec preset or something like that and click on the disc icon. You should be all set from there. it’ll show up in the generated media library from now on.Don
Richard Klimesh
July 28, 2006 at 10:55 pmOK, this is not working. Here is what I have been doing:
Place cursor on timeline on track where I want to insert Video Event FX Text;
Set font, size, and time, which I want to be 3 seconds;
Name preset “BARN CATEGORY”;
Click SAVE icon to the right of Preset bar.BARN CATEGORY is now included in both the Preset dropdown menu and in the Media Generators selection window.
When I call up the BARN CATEGORY preset from the Text Generator drop down menu the length is 5 seconds and that’s what it appears as on the timeline. When I drag the same BARN CATEGORY preset from the Media Generators window it appears on the timeline as 10 seconds! I’m befuddled.
klimvid
Edward Troxel
July 29, 2006 at 1:29 am1. Options – Preferences – Editing tab – change the “new still image length” to be the length you want the generated media.
2. Create a selection area of the desired length on the timeline, right-click it, and tell it to insert a generated media.
3. Use a script to create a generated media of the desired length.
Richard Klimesh
July 29, 2006 at 11:56 pmThanks, Edward, those will work. Why do you suppose it is that the length can’t be set in the Preset?
klimvid
Edward Troxel
July 30, 2006 at 4:15 am -
Gary Alan
August 1, 2006 at 9:46 pmHow hard could it be to drag the right edge on the timeline event back 2 seconds to fit? A pop up dipslay shows the amount of frames you have moved it. Snapping will make it fit a hole.
Gary
Richard Klimesh
August 1, 2006 at 9:55 pmExactly so, Gary, but I anticipate around 300 of these text event inserts on this project and having them the right length at time of insertion will grease the workflow.
klimvid
Gary Alan
August 1, 2006 at 10:47 pmI see. I usually make text events long enough for a typical speed of reading of what is there. Are all 300 text events using the same amount of text? 300? Maybe a book would be better than a video. JK
Gary
Richard Klimesh
August 1, 2006 at 10:59 pmActually, this video is based on a book I have written. The text events are simply 2 to 4 word introductions to scene changes, thus the short duration.
klimvid
Gary Alan
August 1, 2006 at 11:05 pmsorry. I did not understand the extent of your project. Set the Pref-Editing-Still Length to 3 as said before. Save a preset to recall your default font, size, etc.
Gary
