Activity Forums Adobe Premiere Pro Setting keyframes before transitions
  • Setting keyframes before transitions
    Posted by Jay Handleson on August 6, 2006 at 9:38 pm
    I have been using Canopus Imaginate for most of my still photo montages, but am using PPro 2.0 for my latest project for the added control.
    I am setting the stills into the timeline and adding motion and adding my default transition after the clip is set and motion is added. When I set the transition after the clip is set, the keyframes are moved at the beginnig and end of the transition. I want the clip to continue with motion throughout the transition.
    Is there a way to accomplish this without manually adjusting the keyframes to the beginning and end of the transition.
    I am not setting the transition before the clip because some of the clips fade to black and I would be unable to see the motion under the transition.
    Hope that makes sense,
    JayH
    Jay Handleson replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
