Activity Forums VEGAS Pro Setting Image Duration
  • Setting Image Duration
    Posted by 10 on July 7, 2007 at 4:56 pm
    I suspect that I am missing something obvious, but how do you “set” the duration length of an image in Vegas 7? I realize that you can pull the image to length, right on the timeline, but I am referring to manually entering the numeric time-length.
    When I enter a images numeric time in the “Length” box of, say the Video Media Generator” (for a test pattern), the setting does not seem to change the length of the image on the timeline.
    Thanks! Gary
    10 replied 19 years, 2 months ago 3 Members · 5 Replies
  • Gary Kleiner
    July 8, 2007 at 12:47 am
    [Gary Spetz] “When I enter a images numeric time in the “Length” box of, say the Video Media Generator” (for a test pattern), the setting does not seem to change the length of the image on the timeline.”
    After setting the numeric duration, drag out the event until you see the notch appear along the top of the event.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Edward Troxel
    July 8, 2007 at 1:14 am
    To change the defaults, go to Options – Preferences. On the “Editing” tab you can change the default length for stills and generated media. You can also create a selection area on the timeline and then new generated media will be in that area and set to that length.
    Edward Troxel
    JETDV Scripts
  • 10 Create COW Profile Image
    10
    July 8, 2007 at 5:15 pm
    Ahhh, I now see “the knotch”. Gary, that’s very helpful and good to know.
    And, I understand that in the Prefs one can set the default image length.
    But, is there no way to simply enter an image “duration”, numerically–in its properties–and have it expand (or contract) to that size. I grew accustomed to that handy feature in Ulead MSP.
  • Edward Troxel
    July 8, 2007 at 6:13 pm
    You can via a script. Excalibur will let you do that.
    Edward Troxel
    JETDV Scripts
    10
    July 8, 2007 at 11:49 pm
    Thank you, both!
