Activity › Forums › Adobe After Effects Expressions › Setting horizontal position of a layer in one comp from null object in other comp
  • Setting horizontal position of a layer in one comp from null object in other comp
    Posted by David Lawrence on April 30, 2014 at 7:38 pm
    Hi All,
    I need help with a very simple expression:
    I want to use a null object in a comp as a simple slider to control the horizontal position of a targeted layer in a separate pre-comp.
    I used the pic whip on an expression for the position attribute of the layer I want to move and selected the X coordinate of my null object. This creates this expression:
    temp = comp("s7_LLangle3_stable_comp").layer("Null 1").transform.position[0];
    [temp, temp]
    The problem is that when I slide my null object, it changes both the X and Y position coordinates of my target. I only want X (the horizontal position) to change.
    What do I need to change in the expression so that it only affects the X position of my target layer? I’m sure it’s super simple and I’m already close.
    Thanks for your help!
    _______________________
    David Lawrence
    art~media~design~research
    propaganda.com
    publicmattersgroup.com
    https://lnkd.in/Cfz92F
    facebook.com/dlawrence
    twitter.com/dhl
    vimeo.com/dlawrence/albums
    David Lawrence replied 12 years, 5 months ago 2 Members · 2 Replies
