Activity Forums VEGAS Pro setting for external ntsc monitor
  • setting for external ntsc monitor
    Posted by Ralph Bertini on January 5, 2007 at 4:07 am
    Setting up a vegas edit station for the first time and trying to get output to a ntsc monitor. Selected pv to ext mon, looked in the prefs and other settings. What we’re getting is the video output but it’s not locked almost looks like no genlock on an analog signal. Any ideas? Thanks – Ralph
    Edward Troxel replied 19 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
  • Gary Kleiner
    January 5, 2007 at 4:16 am
    Preview to external monitor is for another computer monitor that is hooked up to the video card. To monitor on standard definition NTSC, you would go out via firewire and transcode the digital signal to composite or component.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Ralph Bertini
    January 5, 2007 at 2:46 pm
    That’s exactly how we have it hooked up. We have the drive hooked up one FW Port and the deck hooked up to the other. The deck we’re using is a sony dsr-25 dvcam deck. We’re hooked up to that via bnc cables to the monitor. We’re getting a picture but it is not stable. I’m poking around the interface for some set up menus to check but so far nothing is jumping out at me. It’s not that I’m inexperienced, I work in FCP and Avid, the interface on this is just different. We’re running version 6. Any help is always appreciated.
    Ralph Bertini
    Ocean County College
  • Charles Avanti
    January 5, 2007 at 5:34 pm
    try setting the preview monitor option in vegas to “best full”, see if that looks better.
    Charlie
  • Gary Kleiner
    January 5, 2007 at 7:44 pm
    I suspect that something is amioss with the interface to (or within) the dsr-25. Do you have another device to hook up instead to troubleshoot that?
  • Ralph Bertini
    January 5, 2007 at 9:36 pm
    we tried that too. no go. Are there any prefs we need check
  • Ralph Bertini
    January 8, 2007 at 12:49 pm
    The dsr 25 works perfectly with our FCP station, I’ll try this panasonic dv2000 but there’s no deck control. It’s more likely that some setting somewhere is amiss.
  • Edward Troxel
    January 8, 2007 at 2:52 pm
    I have deck control on my DV2000 deck from Vegas.
    Edward Troxel
    JETDV Scripts
  • Ralph Bertini
    January 9, 2007 at 2:42 pm
    What are your settings, is there a machine template for this unit? We’re suspecting that may have a bum FW card. While I’m not convinced our project settings are totally correct, no matter what we do the ntsc monitor isn’t stable during playback.
  • Edward Troxel
    January 9, 2007 at 4:23 pm
    I would have to look at the deck itself. I seem to recall having to change a knob on the left side. The word “Passive” comes to mind.
    Edward Troxel
    JETDV Scripts
