Activity Forums Apple Final Cut Pro Legacy Setting focus to viewer window using keyboard
  • Setting focus to viewer window using keyboard
    Posted by Jeff Deutsch on May 29, 2008 at 1:08 am
    I’ve been using jkl scrubbing of clips in the viewer and then F9 to insert once my in and out points are set. Trouble is that once I hit F9 focus is changed to the timeline and when I try to use jkl scrubbing again I get the mac “you did something bad” buzz. I then have to re-click on the viewer window. It’s really not a hug issue but it would be great if I could use a keyboard shortcut to return focus to the viewer windows so as to avoid this extra mouse click every time I’ve insert a new clip.
    Jeff.
    Jeff Deutsch replied 18 years, 3 months ago 3 Members · 3 Replies
