Activity Forums AJA Video Systems Setting Component 8-Bit US 48 KHz to 44.1 KHz for IOLA
  • Setting Component 8-Bit US 48 KHz to 44.1 KHz for IOLA
    Posted by Rich Sims on May 20, 2005 at 9:55 pm
    Hello,
    I am working on a project and the person working on the mix has loaded his audio in at 44.1 KHz. To make his life a little easier I am trying to reset the AJA IOLA preset component YPbPR Betacam 8-Bit NTSC US 48 KHz to handle 44.1 KHz. I have copied this preset and gone into the edit function. It does not seem to want to let me assign a 44.1 KHz setting, only 48 KHz. I have not digitized any of my footage yet so even though it seems wierd that the final mix would be done before the edit, because of the specific situation this is possible. It is a taping of a live theater performance
    Is there a way for me to do this or do I have to tell him to redig his material or convert it over?
    Any help is always greatly appreciated.
    Take care,
    Rich Sims
    Steve Covello replied 21 years, 3 months ago 2 Members · 2 Replies
  • Rich Sims
    May 20, 2005 at 10:15 pm
    Hello everyone,
    I just heard from AJA. The long and short of this is that it is only 48 KHz. but apparently if you have a sequence set to 48 and you through in a 44.1 the timing won’t change, which I thought it would. The 44.1 will play out of the system at 48 KHz though.
    Thanks again everyone.
    Take care,
    Rich
  • Steve Covello
    May 24, 2005 at 2:00 pm
    Just my 2
