Activity Forums Apple Final Cut Pro Legacy Setting Audio Default on Log and Transfer to Stereo
  • Setting Audio Default on Log and Transfer to Stereo
    Posted by Chris Woods on May 14, 2013 at 3:39 pm
    I was wondering if there was a way in FCP Log and Transfer to always have the audio set in Import Settings to Stereo instead of Mixed. Is there a way to make that a default in Log and Transfer?
    Not sure if there is a setting to change this in FCP or is it a setting for the camera? The camera we use at work are P2s.
    I have noticed with transfer from other cameras that use an SD card that the import settings are different and there is just a box checked labeled Audio Mixed Down to Stereo. That footage when I load it defaults to stereo, but not the footage from the P2.
    Not sure if FCP made it for you can set a default for that. If anyone can help that would be great.
    Chris
    Dan Brearley replied 12 years, 6 months ago 3 Members · 5 Replies
  • Tom Matthies
    May 15, 2013 at 4:12 pm
    Although it isn’t a default condition, all you need to do to to make your tracks stereo pairs is click button as shown on channels 1&2.
    E=MC2+/-2db
  • Chris Woods
    May 16, 2013 at 12:45 am
    Okay, thanks. That’s what we do now. Just wanted to see if there was a way to keep it like that all the time for I didn’t have to go in and change it.
    I work at a news station and our photogs just started using the P2 cameras and when they log and transfer they are in a hurry and forget to switch that setting a lot and they were wondering if that could be set like that all the time.
    Chris
  • Dan Brearley
    March 11, 2014 at 4:14 pm
    Hi Chris,
    Did you find a solution to this annoying problem in the end!?
  • Chris Woods
    March 11, 2014 at 4:44 pm
    Yes, we figured out some way to deal with it. I believe you can’t set it as a default, but if you highlight all the clips and select the audio adjustment it will change all the clips to that setting before capturing them into FCP. Thanks!
  • Dan Brearley
    March 11, 2014 at 5:06 pm
    Great. I’ll try that. Thanks Chris.
