Activity Forums VEGAS Pro Setting Audio Codec Sony Vegas records with?
  • Setting Audio Codec Sony Vegas records with?
    Posted by Frankie Jones on December 22, 2016 at 11:44 pm
    Hey,
    I wondered if it was possible to set the audio codec Vegas records with when the Record button is pressed.
    In Dxtory for example there is a list of possible recording codecs:
    Are these selectable within Vegas somewhere, or does Vegas just use it’s own codec for recording.
    Aaron Star replied 9 years, 8 months ago 4 Members · 3 Replies
  • Graham Bernard
    December 23, 2016 at 11:19 am
    Never bothered to question this.
    * Grazie
  • John Rofrano
    December 25, 2016 at 6:56 pm
    It is not possible to set the audio codec because Vegas Pro always uses the highest quality which is to record PCM which doesn’t use a codec at all.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Aaron Star
    December 26, 2016 at 10:54 pm
    John is right.
    I would add that you set your recording format in the audio hardware normally. You use the driver applications that came with your hardware to set record format, then you simple select the device or interfaces inside Vegas to record. That goes for the stock onboard audio interfaces also. If that makes any sense.
    You should be able to search this forum, or other posts on Magix’s forum for people trying to use pro audio interfaces with Vegas. I know there have been several posts over the years on this topic.
